orthophoto output problem
hello pix4d
hope you are doing well, i have a common problem in each output the problem is state in the following image
as you can see the wall is not clear enough I’m using DJI Phantom 4 RTK.
in addition to that i don’t need the point cloud and mesh i disabled that before starting is this causing the issue ?
If you do not generate a point cloud then the orthomosaic will be constructed upon the sparse point cloud. It is very likely the reason why you are seeing this problem. I would suggest generating the dense point cloud in step 2 - but you can set the density to low. This should help better reconstruct your project.
