Orthomosaic not processed in the area of vegetation (bushes)
Hi
I have processed drone data in your software, output tiff files empty showing in green filed areas as shown in the below.
Pls give me a suggestion.
Hi
In order to help, we would need more information.
Upload your Quality Report here:
OneDrive
Sir,
I have uploaded report in one drive, pls see its very important and urgent to me
to take decision
waiting for you reply
First I would like to inform you that if you need personal Pix4D support, you can buy our services “Support and Upgrade”:
How-to-renew-support-and-upgrade
Pix4D Support
Then regarding your projects, each of them have many blocks up to 18.
This is due a lack of matching between different blocks because camera could not properly calibrate.
It happens when the surveyed area is very homogeneous such as forest, desert, water.
Trees and dense vegetation often have a very different appearance between overlapping images due to their complex geometry (thousands of branches and leaves).
Flying at a higher altitude often reduces visual complexity and improves the results, especially in forest and dense vegetation environments. At higher altitude, there is less perspective distortion (therefore causing less appearance problems) and the dense vegetation has better visual properties. In other words, it is easier to detect visual similarities between overlapping images in such areas.
For processing, I would recommend you to:
  • Reduce the images scale to 1/2 (even 1/4 if you cannot achieve better results).
  • Use “All Prior”
  • Rematch “Custom/Rematch”
  • Reduce the number of matches
Hope this will help,
