Open project Pix4Dmatic results in Pix4Dmapper
Open project results in Pix4Dmapper, bypassing Pix4Dmapper initial screens, to classify point cloud that was initially created in Pix4Dmatic by now using Pix4Dmapper.
Dear @Susan_Myers,
It is not possible to open a PIX4Dmatic project in PIX4Dmapper. However, if you upgrade to PIX4Dmatic 1.54, you can classify your point cloud directly in PIX4Dmatic using the ASPRS classes. You can change to the polygon selection tool, highlight the desired points, and then right-click to assign the points to an ASPRS class. Currently, it is only possible to classify using the ASPRS classes.
Ryan
Perfect! Thank you for this update. Will do!
