"NoData" areas
Hi All -
We are having issues with the value of the “NoData” areas.
Is there a set value - and can it be set in the processing template?
T Kashon
SolSpec
Hi T,
In Pix4D you cannot replace No data values with any other values. You will need write a script in some programming language to do so. Can you tell me a bit more which no data pixel values you want to replace, maybe by a screenshot?
