No Autotags form PIX4Dcatch in PIX4Dmatic?
If I scan an area with Catch&iphone, have previously laid out Apriltags, and have turned on the autotag recognition (the iphone explicitly asks for the autotag at the end of the recording process, i.e. BEFORE the upload, which means that it must run on the device, i.e. on the iphone), why can’t I find these marked tags in Matic when I want to calculate the dataset in Matic?
Since I have both licenses, it would be great if I could also calculate a data set recorded with Catch in Matic. At least that’s how I understand your advertising message. Yes, I know that works, BUT: **the autotags are gone! I.e. I now have to mark all April tags with MTPs again in Matic? **
If I am making a mistake here, please enlighten me.
If this feature is missing in Matic, please add it to the list
Thank you! :folded_hands::folded_hands:
Hi Manuel,
You need to use the “Import marks” feature - accessible from the top menu or from the menu in “Tie points” panel. Once you do that, you will see all the autotags in the table and you will also see them in 3D, even though they will appear with the MTP shape. We know that the current workflow is not the most straightforward so we are working on improving it and making it more intuitive for the user. Let me know if this helped or if you need further assistance.
Diana
oh ok, wow that’ a fat reply, thanks. :smiley:
tried it and works out super fine! thanks, solved! :folded_hands:
