New DJI Matrice 4E Georeference Issue
Good afternoon,
We just got a new DJI Matrice 4E after having amazing success with the Mavic 3E. Though we do not do it a lot, it is handy that recently we have been able to import the photos from an RTK mission and they are within 1-2 inches with no ground control adjustment. Now when flying the Matrice 4E it would appear the vertical datum is about 20’ off. Since the 4E is brand new is there something within the software that needs to be updated to handle the new photos?
Thank you.
Hi @cgrogg, can you give me more information about your project’s setup? Did you use checkpoints to check the absolute accuracy of your project? How did you determine there is an offset of 20’?
PIX4Dmatic reads the coordinates and the coordinate system from the image metadata. Can you confirm that the values of your image vertical coordinates and the selected image coordinate system are correct?
Good morning @Rhea_Garratt. Would it be possible for me to send you these 2 photos sets so you could process them and see what I mean? I will do my best to describe it here.
We subscribed to the Hexagon Smartnet here in Virginia. I am able to connect the drone to that network and fly our mapping missions. The Mavic 3E for the longest time would not process to the correct horizontal and vertical results unless we used control. Then here recently I flew a mission and realized o wow now it uses the photo information to then switch it to our datum which is Virginia South NAD2011 Us Survey Ft, and NAVD88 us survey ft Geoid 18.
Now we receive the new drone the other day and I toss it up thinking I am going to get the same results, and it is not true. It appears to be close horizontally, but vertically way off. I was just doing test flights in our office parking lot so I did not set specific control out, but I have information on some specific features that make for an easy check.
I would be happy to send you the Mavic 3E photos and then the Matrice 4E photos so you can see what I am saying. Thank you for the help!
Chase
@Rhea_Garratt Also in looking at your supported cameras it would appear the new Matrice 4e is not listed yet. So maybe this is as easy as the developers need to add the new camera parameters to the software?
@Rhea_Garratt Do you have any update on this?
Thank you,
Chase
Dear @cgrogg. First of all a good new is that M4E will soon appear in Matic database, so hopefully your issue will be solved.
But meanwhile, I suppose that M4E project is using a Generic camera model - you can verify it in bottom right corner of the Matic window, the string there should start with Generic_. At the same place you can modify the Image coordinate system to match the one used for RTK mission. Have you done that?
Also Position accuracies in X,Y and Z in Cameras tab will probably be too big for generic model and RTK mission, it might or might not cause troubles, if it does you can easily modify them to more suitable values (by selecting all cameras by Ctrl+A and editing the value).
It would be great if you can share with us M4E images, even a small subset of it would be enough. Thanks
Tomas
Is this topic solved? Can we use a M4E or are there still issues wit MATIC?
This sounds like the classic vertical offset that all RTK drones will have.
If you use only nadir images, then yes you will most likely have low horizontal errors, only to have a vertical shift. To fix this, a single GCP can be used, but the better option is to use Altitude Optimization, where the drone will collect a last flight line from the outside of the project area to the middle and collect oblique images.
You could also just collect oblique images either with a double grid. I use the normal flight mission with Custom GImbal angle of 60 degrees. Then rerun the mission change its orientation 90 degrees. This is create good accurate data for both 2D and 3D outputs.
Don’t forget to use Check Points to check your data.
Do any special settings during the processing need to be set to use this? I’ve been doing the same with my M3E flights, not using GCPs as the horizontal is within 1-2 inches, based on comparison to prior flights, or against the CADD lines loaded into Cloud or using the ortho as a raster in ORD. I setup my mapping flights in DJI FlightHub and every mission ends with the oblique images. I thought that I read somewhere that Matic will toss oblique images if the processing is setup using the Nadir template, but the oblique templated doesn’t seem right. I figured FH set it to take those shots for use in Terra.
Yes, we support M4E.
As @tomas.hynek mentioned it’s very important to make sure that the image coordinate system is set to the one you use for your RTK acquisition, and verify that the camera accuracy is set to cm level.
