Hi Pix4D community
The ndvi map and some of the reflectance maps of a multispectral dataset have been produced partially complete (for reference see the image below). Any thoughts on what might be causing that issue and/or how to go about fixing that issue?
              Hey,
Could you please upload the pdf report? That would allow us to understand the issue.
Kind regards,
              Please see the attached report as requested.
pix_Multispec_EMW_Merged_Cam&SunIrr_report.pdf (1.4 MB)
              @hrushi.kommula, Can you have a look at this article and confirm you have followed the correct steps: https://support.pix4d.com/hc/en-us/articles/360038663932-Merging-multispectral-projects-in-Pix4Dmapper?  How do the sub-project’s quality reports look like? While creating the merges project, we recommend  unselecting duplicate parameters  as mentioned in Step 8 of the How to merge projects article.
              Thanks @momtanu.chakraborty. Looks like duplicating the camera parameters had caused that issue.
Managed to create deliverable outputs by processing them separately and merging them together in a GIS software.
