Good day ,
I am processing data on a big area, would like to know if MTP can be used as MTP and GCP in the same project?
regards
Hi Aly,
Within a Pix4Dmapper project, you can use the points both as GCPs and as MTPs. Here is how to do it:
- let’s assume you already imported GCPs in your project (my example includes 4 GCPs). First, go to the GCP/MTP Manager and click Export GCPs…
- in the GCP/MTP Manager, convert your GCPs as MTPs:
- click Import GCPs…
- a message will appear: This GCP already exists. Do you want to replace the geolocation information with the geolocation from the file?
- click No to All
- the imported GCPs will be automatically renamed by the software and they should look like this (my example has 4 GCPs):
Hopefully this helps.
Teodora
Thank you Teodora,
much appreciate your help, it help a lot.
