I created point cloud and orthomosaic, but Mosaic Editor is not active. Why it does not work?
It also looks like there was no Mesh created even though step 2 was processed. Perhaps the orthomosaic was not generated as well, can you see the orthomosaic in the results folder (project\3_dsm_ortho\2_mosaic)? I’d also check if the orthomosaic generation (GeoTIFF) is selected in step 3 of the processing options.
For a project like this I’d probably use the processing template “3D Maps” , which should set the options correctly.
Hope it helps and that you’ll find the problem! Let us know if you find the solution
Tomi
Problem is solved, I did not create 3d mesh
