I’m trying to output a fully classified .las file, in addition to dsm/dtm orthomosaics, and the output point cloud seems to be missing a tile. The orthomosaic isn’t missing the tile, and the space still shows up in the tie points. What could be causing this? Thanks in advance.
Hi Lucas,
We would need more details to provide assistance in the most efficient way. Could you please send us the following?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
Is there a possibility you created two groups of images?
Hi Nikoleta,
I can still send the files if you’d like, but I found a solution to the problem by going back and re-running step 2, this time merging the point cloud tiles. Not sure what was causing the problem on the first run.
