minimum ground sampling distance a project can have
¿What is the minimum ground sampling distance a project can have?
The minimum GSD will be defined with the flight height to be able to reconstruct an orthomosaic. The minimum flight height recommended is 25/30mts to ensure that the project will process successfully, you may fly lower, but the project may fail or give artifacts.
Best
