I have a large data set which has been split in to 9 sub-projects. The raw data was captured across three flights with the same sensor.
All nine sub-projects have been run through step one of processing however when I attempt to merge the projects I get the following error message.
Cannot merge inputs:(pix4d_cameras_merge.cpp:81) Camera ID 18446744073709551615 not found
Warning w0008
