Is there a way to take the .obj textured meshes from a project that was split up for processing and just merge the .obj outputs for analyses in the 3D viewer?
-CR
-CR
Hello Christopher,
In order to merge .obj files, separate projects have to be merged on Pix4D Desktop. Step by step instructions are explained in the following article: https://support.pix4d.com/hc/en-us/articles/202558529. In case you would liket to merge only 3D meshes, you may try to use other software packages such as Blender, open3mod, Meshlab or other.
Thank you very much for your suggestion. We have taken note of it and we will pass it to the software development team.
Hope it helps
