I am attempting to merge two projects and I keep getting the error that they are not in the same output coordinates even though they are clearly being output to the same ones.
Anyone run into this before?
Dear Ryan,
It is likely that one of the project’s coordinate systems do not match across each of your sub-projects. Please verify that the Image, Ground Control, and Output vertical and horizontal coordinate systems match. You can find more detailed information about the three coordinate system conditions that must be met when merging projects, below.
Andrew
