Masking in Pix4dCloud
Does any kind of automatic masking occur on the back end of processing with Pix4dCloud? I have a dataset that unfortunately has the shadow of the drone at the edge of the frame in a grid lines later in the flight and I’m wondering how this may affect processing/outputs.
Hello @jhaller, Automatic Masking is not carried out on the backend. The software should be able to remove it if it is not present in a reasonable portion of the images. However, I would suggest you process it and see if it affects the outputs or not.
