Pix4D software uses Mapbox as a basemap provider. Mapbox will shut down its Legacy Static tiles API as of November 1st, 2020. Hence, the current and previous version, which uses the older API will have issues with the basemap.
Additionally, due to some internal changes related to improved security, Mapbox is disabling some of its services on June 7, 2023. This will cause the PIX4Dmapper version lower than 4.6.0 to have issues. We do not know the full extent of this change and whether at least the open street map will work or not, but we assume that nothing will work.
Problem:
- No basemap/tile is displayed.
Solution
Update the software to the latest version here. Valid support and updates is required to update the software to the latest version. To renew the support and updates, visit How to renew Support and Updates.
Keep using the older version without basemap. There will be no impact on processing and delivering the results. However, the visual user experience will be lower and some operations may be harder to conduct.
Listed below are the software affected by the issue.
| S.No | Software | Affected version | Version with a fix | Fix release date |
| 1 | Pix4Dmapper | 4.6.1 or lower | 4.6.2 or higher | Nov 2, 2020 |
| 2 | Pix4Dfields | 1.7.0 or lower | 1.7.1 or higher | May 28, 2020 |
| 3 | Pix4Dreact | 1.1.0 or lower | 1.1.1 or higher | Mar 17, 2020 |
| 4. | (Android) Pix4Dcapture | 4.9.0 or lower | 4.10 or higher | Oct 26, 2020 |
