I have been noticing that when processing the photos from the Capture App, the offset lines between the initial and computed image positions are normally quite long. When processing pictures from a flight done with an EBee, the lines are significantly shorter. Is this due to the accuracy of the onboard GPS or is there something I am doing wrong?
The accuracy of the eBee is much better, overall the RTK version, but if you create the project from zero, using the images from the SD card, then the geolocation is not good, if you use the project file from the mobile to create the project, then the geolocation is better.
The refresh rate and accuracy of the RTK is really good. I hope one day all the drones at low cost can mount it.
