Hi, does anyone know how can I join contour lines from diferent proyects?
I have to make the cartography of 27.000Ha. I will do it in aprox. 50 flights.
My idea is to process around 5 flights in each project, what will leave me 10 diferent big projects.
So far I’ve been trying to join contour lines of 2 proyects without success. The only way I found, is to import all the points (or dsm) in Global Mapper and make the contours, but this will take much more time, and I don’t think GM will be able to handle with 50 flight data at once… Also I haven’t been able to get as clean contours, with GM or Arcgis, as with Pix4D.
I would appreciate any help.
Thanks.
