Is the datum conversion wrong?
Hi there,
I went through the ‘datum_shift.csv’ in the GDAL file of the program file. Surprisingly, I found that the conversion of HK Geodetic Datum to ITRF96 is different from the GOV publication. I would like to know if this is a problem…
Capture from the ‘datum_shift.csv’ on the left VS the capture from GOV table 1
Thanks a lot
Hello Terry,
Our recommendation is to convert your coordinates before using them in Pix4D.
This community post contains more information about it.
Regards.
