I am trying to process some imagery captured from a X4S (part of a Klau PPK system). I imported the Klau-provided lab-calibrated camera parameters and imported the image post-processed positions .csv prior to Step one. The images in WGS84 came in fine in the Map View (1st capture below). I did not specify a geoid, so the image altitudes are heights above ellipsoid.
When I ran the 1st Rapid Processing step, the automatic tie points and initial orthomosaic preview seem to be inverted. Please see images below. I even swapped the camera to the default one and got the same results. Quality Report link in below:
Thank you for your response. I actually have found the problem and it was not a Pix4D issue. It was related to the PPK image location.csv file I imported into Pix4D prior to Step 1. This file was outputted after processing PPK data. The issue centered on me not removing about 20 logged GNSS camera events for the beginning mission segment (with no SD card) prior to creating the image location.csv. Once I removed these events in the PPK software, and re-exported only the final PPK camera events from the mission, it imported perfect into Pix4D.
I am having exactly the same issue. Can you please tell me more about the “PPK image location.csv file”? i am not clear what you are saying here, and I think this could be my solution.
