I am trying to figure out how much material was removed from a stockpile. It there a way to interpolate the data for section of stockpile that is missing? I have good pictures and data. I can attempt to measure using the cut volume but that only measures a wedge and gives me a lower volume than actual.
Hi @ben1,
The volume is computed using the DSM. You could try to draw a surface in the rayCloud and use enable the Use for DSM and Triangle Mesh option.
This way you should be able to give the software additional information about where you would like the stockpile to be.
Hope this helps,
