Hi all.
Im aware that using consumer grade GPS referenced photos, the accuracy of the project is limited to the accuracy of the GPS (1 to 5mts). Also Ive seen theres a way to manually scale a project with a relative coordinate system and creating manual GCPs with known distance. Issue is that If one chooses a relative coordinate system, the model will not be geo referenced at all (not even with the 1-5 meter precision). Is there a way to mix this methods to improve the inner accuracy without loosing the geo referenceing?
thanks!
