Importing .XML
Does anyone know how to Import .XML files into pix4dsurvey? I know how to export the surface just having trouble importing an existing file.
Hi @jex ,
Here, you can find a list of supported file formats for importing files to PIX4Dsurvey.
Inputs - PIX4Dsurvey
Unfortunately, the .xml file is not included. Would you mind sharing the reason behind your interest in importing a XML file so we can understand the usage better? :smiley: Thank you!
Rosana (she/her)
I was just wanting to check a drone flight that someone else did against my data. Just seems like if you are able to export an .XML you should be able to import one?
