While testing the import points feature to use with the AR capabilities in Catch, the points were in a LABEL,Y,X,Z,… format and in the coordinate system for the point collection in US Ft. It appears that the import correctly brought in the Y,X coordinates but converted the Z to meters and put the point at an incorrect Z. In order to get the points in correctly, I converted the original ft value to meters and reimported and that corrected the height, so it appears something is incorrect in the import routine?
After taking a look at this issue, I was unable to reproduce. The app correctly imports the XYZ measurements in both meters and US feet:
I strongly suggest downloading the latest app version 1.30.2, because we implemented some big fixes that might related to what you previously encountered: https://support.pix4d.com/hc/en-us/articles/360043445632-Technical-release-notes-iOS-PIX4Dcatch
Looking forward to your feedback!
Teo
Looks like that did the trick, thank you
