Import Scale constraint from csv file
Is there a feature to import multiple scale constraints from a csv file?
Not at the moment. In what format do you have the data? If you have the end points of the scale constraint as points, you could import them as GCPs too? Then either draw the scale constraint between these two, or simply use it as GCPs?
