I have a series of shapefiles indicating well locations on a site that I want to import as annotation. I would also like the import to maintain the Well IDs. Is there a specific field name for imported shapefiles that will maintain all of these IDs, ie. attribute field “Name” in the shapefile will be used for the annotation “Name” or tag?
Hi @enord
The shapefile import is a beta functionality and at the moment it is mainly intended to be used to transfer annotations from one project to another.
What I would recommend is to try to first create the annotations on your Pix4Dcloud project and later export these to third-party software and there edit their properties so that you can see which properties are written (and read) from Pix4Dcloud.
