How to print out an image direct from Pix4D
just to show on my customer an image of 3D textured mesh of a project, I want to make a print out, also in pdf, of this. Is there a way to take a picture direct from Pix4D mapper or i need to transfer to some other software?
Thank you for your help.
Michele
In the processing options, you can select to generate the texture mesh as 3D pdf, then in process select to generate 3d textured mesh.
You cant capture images form the rayCloud, but you can take your own screenshot…
