Hello fellows, I am looking for some advice on how this buldge edges can be removed in pix4dmatic , below attached are some screenshots, the default pix4dmatic settings were used.
@yparth1997 I would check whether there is noise in the point cloud in these areas, if there is, I would use the point cloud editing tool to get rid of wrong points (maybe in combination with the Clipping box to make it easier to select the points) and then you could run the dsm and ortho again.
