halo of flat objects in ortho
Hello. I’ve collected data in survey mode (grid) as well as orbit mode around an object at two different diameters. All images collected during same flight. Alta X Blue 2.0 with Micasense RedEdge-P sensor.
I end up with a “halo” of flat objects that appears to be georeferencing error. I’ve processing using different parameters (including unchecking multi-scale) yet still not resolved.
Attaching image of football field (flat) and you can see the halo of yard markings (especially the numbers) in the northern part of the image but not so much the southern. This is from images taken in orbit mode at two different radii, same flight. If I process the two different radial orbits separately, no halo but when I pull up orthos into ArcPro, the offset of images is still evident.
