GDA2020
Is there any planned updates to introduce the coordinate system GDA2020 (Geocentric Datum of Australia 2020 - EPSG:7844) for the image geolocations?
Thanks,
Hi Malcolm,
If the desired coordinate system is not available in our database, you can import it using its * .prj file.
This might help you to create your *.prj file:
adding-newer-coordinate-system-definition-to-an-older-version-of-arcmap
EPSG REGISTRY
Hope this will help,
Hi @Malcolm_Harvey,
You can test now our new preview Pix4Dmapper 4.6.1 which contains GDA2020 :slight_smile:
Regards
Summary:
GDA2020 is available in Pix4Dmapper since 4.6.1 Preview.
The first recommended stable version of Pix4Dmapper that contains GDA2020 is 4.6.4.
Regards
