Would it be beneficial if to have a steel plate on a pole (driven into the ground) installed in the ground and a high visibility point marked on it, and have a survey crew give that as a GCP reference?
This would be for earthworks construction with ongoing surveys needing quantities, like a mine or gravel pit type application. That way I can use the same GCP and not have surveyors do tie ins on every mission correct?
