I’m regularly measuring vegetated stockpiles in Pix4Dmatic. The point cloud captures the top of the vegetation, not the dirt surface. To get an accurate dirt volume, I need to shift the base elevation of the volume polygon by a consistent amount (e.g. raise all vertices by 2.5 ft).
Currently, the only way to do this is to click on every single vertex and manually change the elevation one by one. On large stockpiles, this becomes very tedious.
Requested feature:
Add an option (maybe under Align Vertices) called “Offset All Vertices” that lets me enter one value that gets added to all vertices at the same time while keeping the non-planar surface.
This would save a huge amount of time for anyone doing stockpile work with vegetation.
Would love to hear if others are dealing with this too.
