so I get the Message “Faild to create Folders” every time I try to log in Pix4fields. The path isn’t stored on my local device, we use a storage on our server. I can’t switch the path because the message will not go away. As a result I can not log in . I use fields on Mac.
I had the same issue but on windows. Make sure that your computer has not changed the drive letter. that I what screwed me over. I had the exact same issue your having and changing it back to the correct drive letter fixed it.
Make sure that the disk is not selected as the final folder. (for example, D:\ or E:\)
Create a folder inside the disk and select the latter. (for example, D:\PIX4Dfields\)
Make sure that no special characters are used on the path to the folder like middle bars.
Ensure that the storage disk hasn’t changed. Sometimes from D:\/ to E:\ or vice versa.
