When I try to export a PDF report’ operation, Pix4d gets freeze at loading 40% and it can be hours without finishing or giving an error.
This only happens when I try to export an operation for spot spraying.
Could you please share the project log files? Go to Export, log files.
sure thing.
thanks in advance
4d184f11-276e-49a6-9319-85c000ffeb94_logfile.log (385.6 KB)
applicationLog.log (360.8 KB)
Thank you, as I can’t replicate on my side, we will need the compelte project, if you can, please go to Export, Project. I will share a link to your email
Alright, thank you. I will send u the project to your email.
For the record. This error that I am getting is not only with this project. It is happening with all projects since pix4d updated last time.
I do a prescription based on a TGI index of a RGB flight. Following the steps of this video. https://www.youtube.com/watch?v=W-ycuKz1DF0&t=12s
so When I export the pdf, it stops loading at 40% and it stays there foreverm, and sometimes it happens the same when I try to export an operation for a generic tracto on a GEOTiff file.
I tried to send you the project, but archives are too large to send them through here.
I sent a link though GOOGLE Drive.
Got it, I already uploaded the project.
Thank you! we will investigate and get back to you.
Hi there, is there any news about that error. I still cant do any PDF report with Spot Spraying.
Hi, yes, we found it is related to the size of the Operation. We are working on a solution.
You will have to increase the grid size to export it to the PDF for now. Try around 0.5mts or more.
Hi, I just tried 1 m operation’s size and it worked out. 0.5 did not work. So I am trying in the range of 0.5 to 1 m and see what it the smallest I can go so far.
Thank you so much.
