Is there a way (similar to in Mapper) to have a manually moved vertex be adjusted vertically to match the vertical value of that points triangulation? This works great in Mapper and could create a location that might even be more accurate than the points that are automatically rendered.
In the current configuration, it appears that when you manually move a vertex and messes up the elevation completely.
