DSM shows high vegetation in the contours file. Looking at the point cloud the vegetation is classified correctly but it’s still showing up in the contours file.
Seems to remove some but not all any guidance would be appreciated.
Joe
Joe
Hi @joe.gatti,
Thank you for your question and welcome to the Pix4D Community
Yes, the contour lines are taking into account the Digital Surface Model (DSM) if no Digital Terrain Model (DTM) is generated. You need to enable the DTM generation as only the Ground and Road Surface groups are preserved in the DTM.
You can find additional information here:
Happy mapping!
Hi Daniele,
Thanks for the response. I have those setting checked in option 3, see below.
I did watch the video on that link just so you know.
I’m running version 4.8.0 if that makes any difference.
Joe
Hi @joe.gatti
Thank you for your reply.
Could you please open your DTM to see if it shows the vegetation?
(click Mosaic Editor on the left sidebar > Select DTM in the droplist at the top of the PIX4Dmapper window) The DTM will appear with a color scale.
You can also try to use a different Surface Smoothing in the DSM Filters.
Also, did you enable Point Cloud Classification in step 2?
Hi @Daniele_Lecci
Yes I do have classify point cloud checked. The DSM and DTM both look pretty good to me see below.
DSM
DTM
Thanks again for the help.
Joe
Hi @joe.gatti,
Thank you for the screenshot.
Yes, the DTM looks smoother than the DSM, but part of the vegetation is still visible (image below)
Only the Ground and Road Surface groups are preserved in the DTM. To improve the DTM, all the terrain points should be assigned to one of these point groups. To manually move points between the automatically generated point groups, the Edit Densified Point Cloud option can be used: How to edit the point cloud in the rayCloud. If the point cloud classification has not been generated, which is not recommended, all the points are treated as non-terrain points and the DTM is a smoothed version of the DSM.
Hi @Daniele_Lecci,
I’ll give that a try and let you know how it goes.
Thanks again.
Joe
Hi @Daniele_Lecci
I tried editing the point cloud to make sure everything was assigned to the correct category but still get the same results in my contours file. Here’s another example.
Mosaic:
What am I doing wrong? The contours file would be great if I could get rid of the tress and man made stuff and it’s a lot cleaner than the contours file that come out of Drone Deploy but until I can get this resolved I’ll have to use the Drone deploy one when there’s high vegetation on the sites I’m flying.
Any help would be greatly appreciated.
joe
Thank you for all the new information, @joe.gatti.
Please try to assign the points belonging to vegetation and buildings to the “disabled” group and process the DTM again.
In fact, the DTM interpolation:
Hi @Daniele_Lecci,
I don’t suppose there’s a easy way to do that…like click on the points classified as high vegetation and disable them all at once? Or I have to manually outline each thing and disable it? If that’s the case it seems like it would be a waste of time classifying the point and generating the DTM automatically in the processing option.
Hi @joe.gatti,
When you open the legend of the different classes, you can turn on/off selected classes.
Select only the High Vegetation, Building, and Human Made Object classes.
Assign the points belonging to these classes to the Disabled goup:
Disabled classDisabled classNow you can create your DTM and contours.
Please let us know how it goes.
Hi @Daniele_Lecci ,
Ok, that looks much better. Still need to do a little tweaking but that will do the trick.
Thanks much.
joe
