Is the latest version of Pix4D Fields compatible with DJI XT2 for mapping thermal pics?
Hi Donald,
PIX4Dfields currently supports the Altum and Sentera 6x for thermal. Unfortunately Fields does not support the XT2. However, if you simply want a map that does not contain any radiometric data (i.e. temperatures) then you should be able to process with a custom XML camera parameter file. If you attach five images I can generate the file for you.
