I don’t know if anyone else has solved this issue…I thought I would share. Using a DJI Spark for Mapping I found out that the Geo location in a Taken Photo has been truncated to to the nearest minute. Therefore on flights if you process the data using Mapper it looks like a grid and the Photos are grouped. I was able to Fly the Drone using DJI Go4 and download the Photos off the Drone. I then use AirData Uav to download the Flight log. The Flight log has a table showing Lat and Long and Altitude when the Photo was taken. I clean that table up to shown only that info. When Processing the data in mapper clear the exif and reload from file. This will give accurate photo locations for processing. However this mean you can’t use pix4d Capture as a flight log is not created
Related topics
| Topic | Replies | Views | Activity | |
| PROCESSAMENTO DJI SPARK NO PIX4D MAPPER | 2 | 331 | February 18, 2021 | |
| Como processar imagens do DJI Spark no pix4D versão 4.3.33? | 2 | 267 | February 19, 2021 | |
| Incorporating DJI photos with incorrect EXIF GPS data | 3 | 989 | March 31, 2021 | |
| Point Cloud (and Geotags) appears Shifted from Camera Photos | 2 | 446 | July 31, 2016 | |
| Map Pilot app from Mapping Made Easy | 29 | 1367 | October 29, 2015 |
