Currently running a pix4dcloud demo,
I’d like the possibility to add multiple .tif dsm surfaces or even more so .xml surfaces as design reference surface, separate from the UAV dataset so that analysis can be done between the generated mesh and design surface. Also a contour display with interval imputs for .dem surfaces on top of the elevation banding that currently exists.
