I am developing a flight plan with the hopes of making a topographic map of an area with a lot of vegetation, and I am assuming that means I will generate a DTM from Pix4D.
My intended area is approximately 8 acres of forest that should have minimal leaves. I plan to fly at 90% overlap for both frontal and side.
Looking through the support and community pages, I seem to be getting a lot of conflicting information.
NADIR vs. Angled images:
In this post, the P4D project manager recommends Nadir Grid Flights:
In this post, the community manager recommends an image angle of 10 to 35 degrees:
First question, which is the best for what I am trying to do?
Flight Height:
This article says that for a forest, “best results are obtained with a GSD higher than 10cm per pixel.”
Lets assume that I fly at the maximum allowable 400 ft allowed in class G Airspace, will I really get better results than at 200 ft? And if I could get clearance to fly at 1200ft, would the Mavic 2 Pro even see anything from up there?
I am completely new to DTM generation and topographical maps, so if I am missing something, I know it is my inexperience. It just seems that the recommendations I have found from Pix4D are confusing.
A Digital Terrain Model will try to generate the elevation model without the vegetation.
A Digital Surface Model, will generate the elevation model including the vegetation.
As you have found there is no real truth on this topic, as the area you need to fly is not that big, you can try both nadir and oblique flights, have it compared and see what gives you better results. Personally I would go with Nadir and at least 85% overlap, front and side.
