Tie points are 20m above the calibrated images. What may be the reason for it?
Hey Rohini,
Under Calibration tab/Calibration select All Prior for the Internal Parameters Optimization to see if that makes a difference.
I’ve seen similar results when mapping with Mavic Pro without rolling shutter correction and without GCP’s. You should also check if that’s the reason for these kind of results
Selim and Jaakko have a good point, you should try their suggestions ![]()
Could you also share screenshots of the quality report to better understand the case?
