CP in 2D
To explain briefly my project, I do a work for a boundary delimitation so I only need to have coordinates in 2D.
That’s why, I use GCP in 2D and I want to control the results with CP in 2D too.
But, is it possible to use CP in 2D in Pix4D? I only find the way to use them in 3D.
I thank you in advance for your help,
Sincerely,
You can go to ray cloud, create manual tie point, then just change x y coordinates, and leave z from project, then change label from manual tie point to check point :), then process again
