Converting Temperature Units to Celsius
Are you planning to add other units to the data representation, such as Celsius? I think this could be done in a similar way to how the decreases are shown (as percentages or degrees).
Mathematically, it’s simple—you just need to subtract 273.15.
Hello @mwywial
Converting Temperature units to Celsius, Kelvin, or Fahrenheit is already possible in PIX4Dmatic.
You can convert the units either from the bottom bar inside the project or from Preferences> Display> Units as seen in the image below:
I hope this helps.
Spachos Anastasis
I didn’t see that; thanks for your help. You can close this thread.
