Controlling processing time
I have generated the quality report of a project I created before to check its processing time again.
I remeber it was written in the report the first time, but the second time I generated it, it was not present.
Is there a way to control the processing time again please?
Such a result happens when you are re-process the Quality Report after Step 1 was completed.
Unfortunately, there is no other way to trigger the time computation than running Step 1 again.
Regards
@nardone.raffaele.202 If you go into the .log file you can pull out the total time spent on any step.
Thanks @rsweeney.
