I want to create an accurate 3D model of a building exterior using Phantom 3 imagery (12 mega pixel stills with 80-90% overlap). I will use a Trimble R10 GPS to survey ground control points close to the building for georeferencing and accuracy.
If I also use a highly accurate total station to survey targets placed on the building and assign these coordinates to the corresponding point in the photogrammetric point cloud, will it increase the accuracy?
Thank you
