Hey folks,
We are using Pix4DCloud to share interactive orthomosaic maps with our clients, but something that’s causing us frustration and our clients confusion is the default map view - it’s zoomed out too far i.e. from space. We need users to be able to see the area that they are expecting to see without having to provide them instructions on what button to press to bring that portion of the map into view manually.
In other words, is there a way to set a map’s default view to the same view you get when you click “Center Map”?
