Can I export clipped image?
I have flown a Cement Mixer truck, (large, rotating barrel type), and processed it. I took GCP measurements around it as it is a crash recon case and I need proper scale.
PROBLEM: I need a bird’s eye view, (ortho), of the truck to place on the roadway where I can clearly show the center line of the vehicle, (and thus its relationship to the road), at the bumper level. However, the mechanical concrete chute is anchored right above the cab and extends forward, obscuring the center line I marked on the bumper when seen from above.
I know I can create a clipping box and factor out the chute, but how do I then save that clipped image in a way to export to my mapping program so that the clipped parts don’t transfer as well.
Thanks for any input.
Dennis
Hello @denniscrawfordky, After you add processing area, only the results inside the processing are will be generated. So, the workflow would be, processing step 1, adding processing area and than processing step 2 and step 3 so that your point cloud or orthomosaic will only have that area.
Thank you, sir! I appreciate the reply and will try that.
