Camera files with standard distortions
Hello, after doing the whole process, I need some parameters and I can not find them in the report, these are the parameters I need. the camera that I use is FUJI XM1 18mm PRO
calibrated focal length (m): c
main point (mm): x0
Main point (mm): y0
radial distortion: k1, k2, k3
decentering distortion: p1, p2
affinity and nonorthogonality: b1, b2
I hope you can help me.
Hi Duvi,
After running Step 1. the optimized camera parameters are saved in:
As a side note, parameters b1 and b2 are not optimized and included in the results.
thanks
