Hello, I wanted to know if its possible to get calibrated external and internal camera parameters in text file like it is in Pix4Dmapper? I can find these files in Pix4Dmapper project folder but I cant find similar files in Pix4Dmatic project folder. Pix4Dmatic does have a button to export image geolocations and orientations but this has same values as image EXIF data and not calibrated cameras.
Hi, you may find this data in the Open Photogrammetry Format (OPF) export in in PIX4Dmatic: File > Export > Project as OPF.
You can find more here:
- This is the general page for OPF: The Open Photogrammetry Format
- Here you have the specifications: GitHub - Pix4D/opf-spec: Specification for the Open Photogrammetry Format (OPF)
- and here some python tools: GitHub - Pix4D/pyopf: Python library (and tools) to make it easier to work with OPF projects in python
Let me know if you find what you need.
What are you using these for?
