There are times where I do two different datasets in a single project on the same day. This causes an overlap in maps in the timeliner. To avoid this, I have to zoom way in to that day to see the map.
It would be great if there was a button where I could just go to the previous or next map instead of having to use the timeliner.
Hi @jcadwallader
Thank you for your feedback! This has been passed to the product team.
Notice that you can also change the capture date (and time) for your project so that the two datasets will result less overlapping in the timeline. Hope this helps.
That would make my maps inaccurate. If we were audited or ever need to look at a map for a specific day, the data would be off.
